It sounds like the regulator has a stuck valve or ruptured diaphram or something. They are simple but there shouldn't be liquid getting to the carb.
Generally you start on vapor and once you have a little water heat you switch to liquid. Nothing is harmed by starting on liquid, but the regulator can literally freeze up due the latent heat of vaporization.
Running on vapor alone will not allow you to make full power because there's not enough volume of energy coming from the tank. Engines always run on a mixture of fuel vapor and air and starting on specifically on vapor makes operation easier in cold weather. In the hot Texas sun I can start and run on liquid with no problems.
The vapor valve has a tube that goes to the top of the tank and the liquid valve has a tube going to the bottom. Generally they are labeled. A photo could help as there's umpteen varieties of tank valve configurations.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
