Re: Farmall 460 rear end
Posted by pete 23 on May 08, 2012 at 20:31:30 from (74.32.231.176):
In Reply to: Re: Farmall 460 rear end posted by Dan Osborne on May 08, 2012 at 17:00:56:
The upgrade won't make a whole lot of difference for the short haul as it was for durability and not actual added strength. I've seen more than one 460 break an axle housing plowing so hard telling what it would do in a pull. All depends on your weight class and speed of the pull. We never sold any 460's with the small axle. If you are going to replace an engine I sure would pull a brake and look to see what you have inside. Might find a few other surprises as well.
