How are you going to go thru a field for the first time just knock down unpicked corn so you can pic two rows. With the mounted you could go thru anywhere. With the pull picker the tractor would need at least two rows for space to pull the picker. We used to go thru before picking and hand pick two rows throwing them on piles then pull a wagon knocking down the two picked ones and pic up the piles so there would be room for the tractor drawn picker to get thru. Opening up a field took a lot of hand picking just think all around the field then at least two places in the middle so you didnt drive empty clear across to the other side. got it
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
