Mike: Using a mounted picker was not always better. Going through wet/muddy areas would tend to plug up the narrow front wheels even if you had mud scrapers on. Using a pull type picker with a tractor using a wide front seemed able to work better in muddy conditions and late Fall when it was getting colder the muddy fields stayed muddy often untill Spring. So just knocking down a few rows with a pull-type picker was not always a clear cut loss if you could get through the rest of the muddy field better then a narrow front mounted picker.. A plugged narrow front under all that sheet metal nose cone was a pia problem..
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
