Re: MOUNTED corn picker VS. Towed type.M Farmall.WHY ?
Posted by Duner Wi on May 09, 2012 at 07:01:09 from (216.226.80.242):
In Reply to: MOUNTED corn picker VS. Towed type.M Farmall.WHY ? posted by Mike1972chev on May 09, 2012 at 02:54:37:
Mounting picker on M was a bit of a hassle as I remember. This is before we had impact wrenches.
Opening the fields was also a hassle with pull type.
