Looking at the books again I see the pressure relief on the primary pump, looks fairly easy to get to. The other one you mention is the fuel return check valve?
I did pull the side cover off the pump this morning but could only see the end of the rack and that didn't do me much good. Was working solo this morning and couldn't see in there and move the throttle easily. When I get a chance I'll puller the filler neck and check from there. I'll also put new filters in it anyway.
I definately have some amount of fuel flow as opening any bleeder gets me a stream of fuel, also at the top of the plunger.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
