Re: Farmall m propane problems.
Posted by Centex Farmall on May 09, 2012 at 15:23:42 from (166.147.72.15):
In Reply to: Re: Farmall m propane problems. posted by Andrew Psencik on May 09, 2012 at 14:30:41:
Yeah, your problem is in the vaporizer. Just giving some background on why some people flip out over the whole liquid/vapor thing.
The H parts look similar but will be too small for the M. The carb will be too small for full power and I'm not sure it will even bolt on.
You might check with your local propane dealer to see if they have a good used vaporizer. If you're handy with fabrication you can mount any reasonable sized unit on the tractor. They may even have a good used one if a new one is more than you want to spend.
