Unless you were doing a TOTALL teardown(which you obviously DO NOT need.) I would not go near the engine or the trans/final drive with a pressurized sand blaster at all! Most people do not realize that the sand under that kind of pressure WILL get into areas you dont want it to! I dont care HOW much duct tape,corks,plugs,block off plates you use.
You might look into low pressure,[lastic media blasting,but it will still enter any cracks or crevases. A good cleaning and some hand prep work like posted below will produce "show quality" results.It is in the detail as to how much you want to "work" at the prep job???? The prep work IS the key to GREAT paint.period!!!!
Even if you DO choose to sandblast it,you will have as much prep afterwards as you would have if you didnt blast it. (Sand clean up,taking it FARTHER apart to get the sand out of areas it should have NEVER been.) IMHO,If I were going to blast it,I would start tearing it apart even more than it is now.You wount get good coverage with the sand.TOO many angles to hit.You will find yourself taking things apart afterwards to finish them.
The old paint that is on it+ MORE primer will work good as a base IF IT IS PREPPED CORRECTLY! ;) I am sure I will get arguments here. :) Unless a tractor was a "rust bucket" of a chasssis,(which yours OBVIOUSLY is not!) I wouldnt.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
