Re: MOUNTED corn picker VS. Towed type.M Farmall.WHY ?
Posted by RPM1941 on May 10, 2012 at 07:53:04 from (173.23.76.185):
In Reply to: Re: MOUNTED corn picker VS. Towed type.M Farmall.WHY ? posted by Kirk Affeldt on May 09, 2012 at 16:35:16:
The 234 could be had with hitch lift or hyd cyl lift, most of them were hitch that I set-up, 234 had a lot easier/quicker set-up to take the processing units off, they advertised use the tractor for chores in morning & pick corn in afternoon. Problem was that the mounts for tractor were very specific for each model, not much fit a IH 656 or over to 706, they were factory made to each tractor. To set-up all equipment we had a 706 with 2000 IH loader & fork lift attachment. I am not sure what extensions you are asking about, the elevator we just man-handled it on or lifted with loader/706.
