I ran a NI mounted on a 300 for a couple of years while we could get corn shelled at our feed mill. The tractor+ picker is 100% noisier. There are all those chains and gears rotating and whirling along with the picker itself holding in the tractor noise.
Definitely dirty, hot machines to run with all that corn dust being stirred up and sent back at you by the radiator fan, especially on warm September afternoons in Ohio.
We broke the rear axle several times with the added weight of the picker.
Mounted pickers only came in wide row varieties, unless they were 1 row pickers. I think that lead to their disuse over the years more than anything else.
All that said, I think I would rather pick with a mounted unit vs pull type if I was still picking corn.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
