Little Genius plow
Posted by Nate V. IA on May 10, 2012 at 12:39:28 from (173.215.42.116):
Hey guys I borrowed my dads 2 bottom plow and was using it to tear up about an acre, on the last pass the clutch lift kept acting up. It didn't take long to figure out the return spring that holds the lever back had wandered off. I know I could use a bungee cord but the plow isn't mine and I'd like to return it in better shape than I got it. I need the approximate size of that spring.
Thanks
Nate
