Re: hydraulic oil leak
Posted by glennster on May 10, 2012 at 14:34:35 from (76.222.59.15):
In Reply to: Re: hydraulic oil leak posted by pheel on May 10, 2012 at 13:08:21:
nope, the hydraulic pump is mounted in front of the distributor. if you go to the case i-h website and search for parts, it will show a blow up diagram of the distributor and pump set up. if you havent done it before, you may want to pick up a repair manual as you need to keep the timing correct when you pull the distributor and pump off.
