Re: starter brushes for 1948 Farmall Cub
Posted by Bill {Antique Acres} on September 24, 2000 at 20:41:20 from (63.162.254.101):
In Reply to: starter brushes for 1948 Farmall Cub posted by Calvin Robinson on September 24, 2000 at 17:10:13:
I had to replace the gear a while back and searched high and low for it. I called every parts place and NAPA even couldn't get it. I ended up having to get it at the friendly Case/IH dealer. It is not cheap either. If memory serves me right in the neighborhood of $30. I just had to replace my rotor last weekend and it was $24. If you can find one in a graveyard that would be good. But make sure the teeth are in good shape on the gear and the rotor. The old ones are metal and the new ones are plastic if you do buy a new one. Bill {Antique Acres}
Post A Followup
: Re: Re: starter brushes for 1948 Farmall Cub
