F-30 Engine Question
Posted by BT in NE on May 10, 2012 at 18:13:34 from (98.16.146.198):
I have taken my F-30 engine down to the front cover plate to replace a timing gear. While I am this far, I would like to replace the gasket between the block and the 1/4" thick steel plate. How much of a job is it to remove the bearing retainer to do this? I have the gasket and it seems like now is the time to replace it, or do you think I should just put it back together and hope it doesn't leak? Thanks for any advice. BT
