Re: 1566 IH Lift arms wont go down
Posted by The tractor vet on May 10, 2012 at 20:06:40 from (76.212.225.27):
In Reply to: 1566 IH Lift arms wont go down posted by biggerred on May 10, 2012 at 19:51:00:
Pull the top link plate off and look over on the right side towards the top and you will see a lever arm hanging down and you will see a lever-arm coming up from the bottom . The one on the top is suppose to be on the back side of the one coming up from the bottom . Now a word of caution thinks can be SHARP and the top arm is heavy spring loaded , myself i have a hook to use to pull it back and around the bottom one . This happens when the three point arms are jerked hard and causes things to jump places they should not be . This will take less then fifteen min. to fix.
