Re: What's this bolty thing called?
Posted by Brownie 450 on May 11, 2012 at 04:14:18 from (66.43.241.198):
In Reply to: What's this bolty thing called? posted by 400D Guy on May 10, 2012 at 11:35:59:
D82 is right on the cultivator. You drove in to the culti, & swung the side sections in toward the tractor. These pegs located the plate that went up against the tractor frame. 2 hook bolts went from the plate to the frame. You could actually dismount the culti. in 5 minutes.
