Re: Cub Clutch question
Posted by mkirsch on May 11, 2012 at 05:31:26 from (64.80.110.75):
In Reply to: Cub Clutch question posted by Farmallb on May 10, 2012 at 20:51:00:
You may be able to cure the problem with two simple adjustments.
1. Raise the fingers on the pressure plate slightly so the pedal can get more lift.
2. Readjust the pedal free play so the clutch completely releases, and doesn't "tick" when you have the pedal fully depressed.
You may not end up with an exact perfect free play measurement, but you might be able to eek some more life out of your clutch this way.
