Re: FARMALL H max tire size
Posted by rustyfarmall on May 11, 2012 at 06:54:17 from (67.55.162.174):
In Reply to: FARMALL H max tire size posted by WSJ on May 10, 2012 at 15:01:15:
The factory rims are only 10 inches wide. Optional was an 11 inch wide rim. An 18.4 tire is WAY too wide for either of those rims. If you want to an 18.4 tire, you need to get the cast centers from a Farmall 300 or 350, and 16 inch wide double bevel rims. The double bevel rims will NOT bolt up to the existing Farmall H cast centers.
