Re: Lo-Boy runs 10 min's stops
Posted by The Red on May 11, 2012 at 15:24:30 from (69.246.205.0):
In Reply to: Lo-Boy runs 10 min's stops posted by Co2cub on May 11, 2012 at 13:26:47:
If it is dying then waiting a several minutes then runs again, could be the coil breaking down. When it quits, see if the coil is real hot. Don't grab it, you might get burned!
