Just looked at a pilot's forum if your aircraft has been STC'd (airplane speak for modified) to run autogas and you set it up to run Autogas but run 100LL your engine will run RICH if your engine is set up to run on 100LL but fuel it with with autogas it'll be lean, in fact lean enough to cause engine damage. Rotex (airplane engine manufacturer) recommends setting their engines up to run on Autogas but occasionally run a tank of 100LL through it. One forum pointed out that airplane engines are low-speed and relevantly low performance , a Continental IO 550 is 550 cubic inch engine rated at 300-301 horsepower. Low speed because you have to keep prop speed below the speed of sound or airflow over the prop gets messed up and your prop efficiency goes to heck. Pilots don't like gear boxes, they add weight and it's something more to go wrong, and a smaller engine turning more RPM's doesn't usually last as long. Another interesting comment is aviation fuels have different vaporization characteristics because they are made to be used at higher altitudes.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
