Re: Lo-Boy runs 10 min's stops
Posted by State of Jefferson on May 11, 2012 at 18:53:23 from (75.247.165.249):
In Reply to: Lo-Boy runs 10 min's stops posted by Co2cub on May 11, 2012 at 13:26:47:
My cub did that a few years ago, after setting for sometime. Tried everything. Got the notion that maybe there was a little water in the carb. Took the drain plug out for a second, put er back in. Ran like a champ from then on.
Ben
