Re: Photos of the SMTA-LP with different tank
Posted by Wardner on May 11, 2012 at 21:28:02 from (4.154.225.20):
In Reply to: Re: Photos of the SMTA-LP with different tank posted by John A. on May 11, 2012 at 20:47:25:
The TA code is either S or R. R code is w/transmission driven PTO (non live).
It was probably built with the S code so that the tractor would be more useful in the off season when the picker was pulled off or when the tractor was retired from picking duties.
The S means that the main clutch pressure plate was splined for LPTO. It also means that the driving and driven gears behind the clutch as well as a couple shafts were installed. It does not mean that the planetary rear unit was installed at the factory. In fact, Cotton Pickers did not use the rear PTO and the planetary unit was a delete. Power for the Cotton picker is shown below. The pulley runs the fan. The opposite side is connected to a four foot drive shaft that powers the picking head.
third party image
