Re: Super C rope bracket ?
Posted by NoNewParts on May 12, 2012 at 03:26:15 from (67.240.145.237):
In Reply to: Super C rope bracket ? posted by Dean Olson on May 11, 2012 at 18:12:33:
I have a bracket that looks like that one mounted
on the stepped down end of the light bar, right side,
on a 51 Super C
right side light is missing, just that bracket on the right side.
no idea what it's for.
Dean, OT, but I was reading some old posts about a SC fast hitch
and remotes.
You were talking about running another cylinder.
On a SC I recently got with a FH,
lines come out of the factory remote valve, run up
to under the steering wheel to a 'valve'
then back to the FH block.
This 'valve' is basically just a switch.
lever on top lets you select the FH lines or turn it to
send to 2 different fittings on the other side. unused right now.
pick one or the other pair.
It looks like it might work for what you were talking about.
I could post some pics if needed.
This post was edited by NoNewParts at 03:36:08 05/12/12.
