Re: Farmall 300 oil pressure
Posted by pete 23 on May 12, 2012 at 09:19:58 from (74.32.231.176):
In Reply to: Farmall 300 oil pressure posted by Mark J in Mi. on May 12, 2012 at 08:45:40:
That is a lot of drop, but it all depends on if this is something that just recently happened or if it has been doing it for a long time. It is definetely not a normal situation for a lube system in good over all condition. Could be leaking pressure relief valve, general worn out oil pump, excessive clearance on end plate of oil pump(blown gasket) general loose mains , rod, cam bearings or it could indicate one failing or failed bearing, so , like I said , depends , has this just suddenly happened.
