Re: Stuck 450 Diesel
Posted by El Toro on May 12, 2012 at 10:54:16 from (108.3.225.57):
In Reply to: Stuck 450 Diesel posted by Hfarmall on May 12, 2012 at 07:14:22:
If you can pull that tractor away from any building and remove anything flammable I would pour some diesel fuel or kerosene on top of one piston and set it on fire. The heat should free the piston. You may need to heat the wrist pins to free them. Only do one at a time
and remove the rod cap. Use a piece of oak 2 X 2 and big hammer and try to drive out the piston and rod. I think you need to pull the engine. I did that on a Farmall A back in 1975. Since they have wet sleeves they're easier to remove.
Hal
