Re: Photos of the SMTA-LP with different tank
Posted by redgems on May 12, 2012 at 21:23:40 from (204.14.163.20):
In Reply to: Re: Photos of the SMTA-LP with different tank posted by CenTex Farmall on May 12, 2012 at 19:47:57:
Appreciate the comments!
The old gent said never on picker,However, with the serial tag that says high altitude for l.p. and for high drum axles and G for picker I want to believe that it left the factory under a picker. Special order on propane reason for high alt. pistons.
Tell tale signs would be holes on pedals for connector rods,seperation clamp on bottom of gear shifter,a break with extension clamp on throttle rod.Signs of frame connections on front bolster, signs of frame mounting on top of axle housing about were fenders would mount. As for narrow front must of been owners preference after dismounting picker because he would of had to replace front fork
from high to standard. Tony
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
