The best way would be to find a parts tractor without power steering and use that front bolster.
You could possibly make the PS worm shaft and parts work in the front bolster if you removed the sealing rings on the piston but the PS worn shaft is designed to move in and out to allow it to move the control valve. You would need to remove that end play and then seal off the opening for the steering control valve and then fill the bolster with oil.
The hydraulic system can be removed by removing the pumps and using block off plates over the pump output ports. Remove the auxiliary valves and piping. Then block off the return port to the transmission.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
