Posted by Va Gasman on May 13, 2012 at 04:29:02 from (75.243.226.33):
In Reply to: Stuck 450 Diesel posted by Hfarmall on May 12, 2012 at 07:14:22:
I know what you are up against. I had SH with 4 stuck cyliinders. 2 broke loose using Hal's method of fire in cylinder and a big block of Hickory. #1 had rod bolts on side and had to use unique 3/8"breaker bar with short socket and got those bolts. Hyd jack raised tractor off floor when placed under piston. I contoured a oak block to fit bottom of rod and then chained a 4" peice of steel under siderails,place jack on that and started jack process and fire in cylinders. This worked but it pushed the sleeves out to and then used press to get pistons out. Randy
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
