Re: 460 Farmall power steering delete
Posted by Mitchel - 460 Farmall on May 13, 2012 at 05:32:16 from (74.190.51.91):
In Reply to: 460 Farmall power steering delete posted by Dan Osborne on May 12, 2012 at 20:29:39:
I was about to do the same thing on my 460 ie delete power steering and all hydralics. Started thinking the 460 uses two pumps one for hydralics and one for power steering if I could remove hydralic pump and maintain power steering pump. Here is what I am going to try. I am going to remove pump gear from hydralic pump to disable it but still alow it to drive the power steering pump. If this works like I think it will the hydralic pump will work as the adaptor that was installed in tractors that came without lift hydralics originally. Not sure if this will work but I plan to start tomorow. Will update when I finish.
