2). If you have changed from Positive Ground to Negative Ground and leave the ammeter as it was there will be no damage. The ammeter will, however, read in reverse. That is it will show a discharge when the alternator is charging the battery instead of the other way around. All you need to do to rectify this is reverse the wire at the back of the ammeter.
As to positive and negative ground. There are 6, 12 and 24 volt systems which use negative ground as there are 6, 12 and 24 systems which use positive ground. The battery does not charge any better or any worse with either system. Some alternators will not, however, tolerate being wired up as positive to ground; they blow diodes.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
