Re: Farmall Oil: Detergent VS. non detergent.
Posted by The Red on May 13, 2012 at 17:54:31 from (69.246.205.0):
In Reply to: Re: Farmall Oil: Detergent VS. non detergent. posted by CNKS on May 13, 2012 at 17:31:26:
On the Hs and Ms, 4 areas where you will find non-detergent oil gunk. The Oil pan, the inlet screen assembly on the oil pump and the push rod chamber above the coil/distributor area. Sometimes on the top of the head under the valve cover but not much. Clean those areas and you get most of the problems cleaned out. Then no problem going to detergent.
