If you have a filter, why? But if it does not I would pull pan, clean best I could and run nondetergent oil. If your cleaning an engine with a filter use auto trans fluid and over fill. Crank splash works great on a hot engine and let run a half hour. Drain and repeat if desired. Auto trans works great, oil with a lot of detergent. I do this frequently to semi and earth moving engines at work. Just do it on an early change for better results. To prove it, get hands nasty dirty, put some auto trans in hands and wash up.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
