Re: Cub will not run................
Posted by El Toro on May 13, 2012 at 18:58:49 from (108.3.225.57):
In Reply to: Cub will not run................ posted by Kyrock on May 13, 2012 at 16:51:45:
Check your fire to your plugs while the engine is running. See if you have a hot blue spark to your plugs, should jump about 1/4 inch. If it's yellow and weak you may have a weak coil. Hal
