Re: Farmall Oil: Detergent VS. non detergent.
Posted by Centex Farmall on May 13, 2012 at 20:00:43 from (166.147.72.19):
In Reply to: Farmall Oil: Detergent VS. non detergent. posted by Mark J in Mi. on May 13, 2012 at 17:21:24:
Modern oils, in addition to detergents also have additives that reduce wear, prevent corrosion, neutralize acids and make the oil more heat resistant.
If you were born in 1950 you wouldn't insist on only using medicine that was available in 1950 would you? It's the same with oil. The new stuff has just flat superior.
