Handle forward is dirrect or t/a clutch locked up. T/a clutch should also release or not be locked when the main clutch pedal is pushed in. Look for a connect rod from main clutch cross shaft to the next cross shaft back and see if it moves the second shaft back when pedal is moved down. If so it should be doing the same as when t/a lever is pulled back. Could still be a problem inside or a stuck clutch. To much unknown. So with no clutch problems or other internal ones the tractor should roll in gear when clutch pedal is down or t/a handle pulled to rear. Also even if the pto drive is locked it should roll. Agree with the other posters on looking like water got to a spark plug. Make it a lot better to get turning if only one cylinder stuck.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
