Yes, a wiring diagram would be very helpful. Measured current flows through the ammeter. This means that the ammeter must be wired in series as a part of the charging circuit between the battery and the alternator. If you wire it up in parallel, it will not work. If you wire a voltmeter up in parallel it will work perfectly.
If you had a sufficiently large ammeter, with a reading of say 200-0-200 then you could simply connect it between the battery terminal and the wire leading to the starter motor and alternator etc. This would show all charge and discharge including current flow through the starter while it operates. If you do this with a standard ammeter and then press the starter button the result will be smoke and/or sparks and fire.
Of course, if you are as stubborn as me and live in a place where IHC used Lucas equipment, then you have all the fun of Lucas 6 and 12 volt systems running positive Earth as per Farmall M, AM, AMD, AW-7 etc.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
