Re: Hot Coil?
Posted by El Toro on May 14, 2012 at 03:58:16 from (108.3.225.57):
In Reply to: Hot Coil? posted by Mark W. on May 14, 2012 at 03:46:47:
It could also be a fuel problem. Check the flow
of fuel from the tank after disconnecting the gas at the carb. Should have a full stream of gas. Use a clean container to catch the gas. If that looks ok remove the tube fitting where your gas line connects and look for screen that may be plugged. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
