Re: Farmall Oil: Detergent VS. non detergent.
Posted by NoNewParts on May 14, 2012 at 05:21:06 from (67.240.145.237):
In Reply to: Farmall Oil: Detergent VS. non detergent. posted by dej(Jed) on May 13, 2012 at 17:21:24:
modern diesel rated detergent oil in your choice of weight, depending
on where you live and engine condition.
tractors are our hobby, and on the Farmall brand, most are easy
to drop the pan and clean it out immediately when you buy a tractor.
Don't flush first, drop and clean first, you never know how much muck is in there.
All I've had needed it, and good to take a look anyway for
whatever...pieces of piston skirts, etc....oil pick up problems..
Then put in some new cheap oil with some ATF/MMO/Flush,
drive it around awhile, drain it and put
in the good oil and a new filter.
cheap insurance. I save the flush 1/2 hour oil for lube and cleaning stuff.
