Re: Hot Coil?
Posted by Mark W. on May 14, 2012 at 08:57:39 from (64.83.132.2):
In Reply to: Re: Hot Coil? posted by old on May 14, 2012 at 08:28:12:
I was thinking vent cap but when it was stalling I pulled the cap completey off and it made no difference. It will sit and run full throttle forever. It will only die out when run after a while under a heavy load or working it. I know I have a leaking head gasket but not sure if thats a factor. I will try checking spark next time it dies.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
