Re: 460 Bleed Hydraulic Lines?
Posted by pete 23 on May 14, 2012 at 10:37:46 from (74.32.231.176):
In Reply to: 460 Bleed Hydraulic Lines? posted by higgi1951@aol.com on May 14, 2012 at 09:10:29:
They don't air lock or need to be bled. Something else happened. Are you sure pipes didn't get switched side to side.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
