Re: New 1086 owner
Posted by RPM1941 on May 14, 2012 at 11:00:43 from (173.23.76.185):
In Reply to: New 1086 owner posted by Super Steve on May 14, 2012 at 07:01:22:
The TA cable is notorious for seizeing up after years of use, particularly in colder areas, usually the top end is bent, its a little L shape where it goes into lever, threaded into cable. 86 with cabs had a lot of grief with cab mounts (isomounts), you can test with just pushing clutch pedal with engine off, if cab moves up & down they are suspect. You should examine these 2 areas before attempting any adjustments, it might cure a lot of ills.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
