Re: Super M trouble
Posted by Janicholson on May 14, 2012 at 11:33:12 from (75.105.77.30):
In Reply to: Super M trouble posted by Super M anaic on May 14, 2012 at 10:53:22:
High speed mixture. On the front lower edge of the carb there is an adjustment screw. this screw adjusts the load mixture. It should be about 3 to 3 and one half turn out from all the way in (gently all the way in, not pliers tight)
from that position turn it outward until the exhaust (wide open) is a little smudgy black. Then turn it in until it just clears up the soot in the exhaust. Try running it under full load. If it still sputters, turn it out 1/4 turn at a time till it runs well. If that does nothing, and it is still running ratty, set the points (.020" on the high lobe of the dist cam) and static time it to TDC. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
