Re: Farmall Oil: Detergent VS. non detergent.
Posted by dhermesc on May 14, 2012 at 11:34:17 from (24.248.193.103):
In Reply to: Re: Farmall Oil: Detergent VS. non detergent. posted by pete 23 on May 14, 2012 at 10:48:51:
I'm surprised that someone that knows anything about oil would say that the viscosity of a 15w40 is close to a 30w.
http://www.bobistheoilguy.com/effects-of-shearing/
Conclusion
Base stock oils (especially the newer GF-3 SL) have better resistance to heat like a synthetic does.
The higher the spread between the bottom number and the top number the more VI improvers are relied on for maintaining the viscosity. Better to keep the numbers closer.
All base oils film strength will shear under stress or pressure. The real way to help prevent wear is to maintain higher levels of antiwear additives. This in conjunction with a good base stock which resists breakdown to high heat.
