Re: Amp Gauge after 12 volt conversion
Posted by mkirsch on May 14, 2012 at 11:55:41 from (64.80.110.74):
In Reply to: Amp Gauge after 12 volt conversion posted by TylerFarmallH on May 12, 2012 at 18:31:50:
If you hooked up the battery to positive ground with the alternator, I'm afraid you probably burned up the alternator.
Your alternator should not put out "between 12 and 20." It should put out an even voltage of 14.2-14.8V. Wide variations like you state indicate that the regulator is probably destroyed.
There should be no "ground wire" on the alternator. It is grounded through the mounting bracket.
