Re: bypass a fuel shut off solenoid
Posted by Bob M on May 14, 2012 at 14:09:39 from (74.67.189.51):
In Reply to: Re: bypass a fuel shut off solenoid posted by Allen Burgess on May 14, 2012 at 13:19:44:
Allen - If it works like the solenoid on Marvel carbs installed on Oliver and John Deere gassers, all is does is close the main fuel circuit when the ignition is off to prevent a hot engine from "dieseling" at shutdown.
A properly calibrated non-solenoid carb will work fine however. Simply tape the solenoid wire out of the way so it can't accidentally become grounded. (This may be the "bypass" step the dealer is talking about.)
