Re: farmall h radiator
Posted by Nebraska Cowman on May 14, 2012 at 16:11:57 from (66.252.115.26):
In Reply to: farmall h radiator posted by paul vroman on May 14, 2012 at 15:30:12:
That's the easy part. loosen the bolt clamping the U joint at the front of the fuel tank then tap it a little as you turn the shaft (counterclockwise looking at it from the front of the tractor) and it will screw right out. There will be a woodruff key in the shaft you will have to remove at some point as it will not pass through the bearing. I guess it's self-explanatory that you have to remove the threaded cap on the bolster.
