Re: 230 power
Posted by CNKS on May 14, 2012 at 17:28:08 from (216.144.104.128):
In Reply to: 230 power posted by 400Dtractorman on May 14, 2012 at 17:21:26:
The mixture is lean. First make sure you have a steady stream of gas to the carb. There is also a screen in the fitting that screws into the carb. If both ok, disassemble the carb, removing everything you can without breaking it and soak the parts and the carb body in true carb cleaner, at least overnight. Put a new kit-preferably CaseIH-in it.
