Re: Super H Governor
Posted by pete 23 on May 14, 2012 at 18:10:14 from (74.32.231.176):
In Reply to: Re: Super H Governor posted by TV Iron on May 14, 2012 at 17:58:10:
If carb checks out ok, look at the thrust bearing in governor. If it is completely shot the weights will not be able to move internal linkage far enough to close throttle, however, this does not usually bother at lowest idle positon of throttle lever provided spring tension can be completely relaxed. In low idle you should contact internal stop in governor and spring should hang loose.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
