Got to spend a day spraying with my 400D
Posted by cushman on May 14, 2012 at 18:28:30 from (71.54.65.224):
I finally got to spend a day spraying 140 acres of corn with my 400D.This was a job my '47 JD GW has done since 1987.I have kept a record of the fuel burn on my GW, and with the lite job of spraying,it's fuel burn was 2.0 gallons per hour.The 400 burned 1.375 per hour.The wide front on the GW gives a smoother ride,but the TA and live PTO are curtainly an advantage.Due to making less tracks in soybeans the GW will go back on the sprayer for that job.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
