Re: cleaning bolts
Posted by SadFarmall on May 15, 2012 at 05:13:51 from (112.213.208.22):
In Reply to: cleaning bolts posted by WOpp on May 14, 2012 at 16:30:55:
Muriatic / Hydrochloric Acid is NOT recommended for bolt cleaning. Use a degreaser of your choice. Clean thoroughly. If the thread looks OK, but needs a little more, use the correct die to chase the threads. I firmly believe there is no substitute for using the right tools for the right job. It saves financial and emotional heartache in the long run.
SadFarmall
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
